In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
Sandisk Extreme 128GB LDPC?
April 15th, 2024, 3:56
Hello, does anybody know if this SD card use LDPC ? I don't have pinout for this so I wonder if it's worth to find the correct one.
Thank you
Re: Sandisk Extreme 128GB LDPC?
April 15th, 2024, 5:59
Most probably it is. Can you upload a better photo where all the lines are visible?
April 15th, 2024, 6:20
melvin wrote:Most probably it is. Can you upload a better photo where all the lines are visible?
Sure, here it is.
April 15th, 2024, 6:23
Yes this is LDPC.
April 15th, 2024, 6:30
melvin wrote:Yes this is LDPC.
OK, thank you very much for saving my time.
April 15th, 2024, 6:36
martyjelen, you can check such cases at future at my database: https://www.flash-killer.com/monolith-database
April 15th, 2024, 7:11
arvika wrote:martyjelen, you can check such cases at future at my database: https://www.flash-killer.com/monolith-database
Thank you.
April 15th, 2024, 8:52
According to my research the SanDisk Extreme is using LDPC, but the actual problem with it from my point of view is the encryption that the controller is using, not so much LDPC.
April 15th, 2024, 8:53
Here is my table for the LDPC and other ECC of the various controllers and flash media: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
April 15th, 2024, 9:02
sourcerer wrote:According to my research the SanDisk Extreme is using LDPC, but the actual problem with it from my point of view is the encryption that the controller is using, not so much LDPC.
Thanks. How can I check if SD card controller using encryption?
April 15th, 2024, 10:45
I case you have a donor and the pinout you can use my initpattern tool to write XOR patterns on it, then you can dump it, and then you can use xorsearch to try to find the XOR patterns. If xorsearch doesn't find any patterns then it uses some kind of encryption. Another method I have been using it to read through the datasheet, some datasheets mention AES or AES-XTS encryption.
April 15th, 2024, 11:37
LDPC not will be such big game changer as everyone thinks, because a lot of cases with LDPC used encryption :(
I hope algo will be cracked, so it give some % more solved cases. But not 100%, more likely 20-30%, based on current statistics. But of course I can be wrong.
April 15th, 2024, 18:15
arvika wrote:LDPC not will be such big game changer as everyone thinks, because a lot of cases with LDPC used encryption :(
I was already wondering about this. Thanks for sharing your thoughts on this.
April 15th, 2024, 18:16
sourcerer wrote:Here is my table for the LDPC and other ECC of the various controllers and flash media: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
merci beaucoup!
