Everything related to MRT tools
WD10EZEX-00WN4A0 track 0 bad , possible to DE?
May 4th, 2023, 5:33
I have WD 1Tb, WD10EZEX-00WN4A0.
HDD ready, take time/slow to RDY, SA is accessible. Head test, Head 0 error to read. SA structure test, found some of SA modules error as in pic, I collected error modules only.
Since Head 0 error to read, replaced the head unit with same hdd donor, problem remain. I wonder, the head from donor, when I returned to donor hdd, now donor hdd having same issue as patient.
My question is track 0 bad , possible to DE? Beside patient platter damage donor head due to patient track 0 is bad? Physically, no scratch on platter.
Thanks for help.
Re: WD10EZEX-00WN4A0 track 0 bad , possible to DE?
May 4th, 2023, 6:39
if donor heads got damaged, then almost surely there is some surface problem on side0.
A SW-only solution won't solve this problem...
May 6th, 2023, 1:02
hi Pepe,
Yes, patient hdd platter on track 0 it may damage and if any head that try to read it will be spoiled.
So, no chance to recover user data/DE.
Thank you
May 6th, 2023, 13:02
pepe wrote:if donor heads got damaged, then almost surely there is some surface problem on side0.
could it happen due to lower (or instable) spindle speed caused by partial seizure?
In this scenario i would aspect micro scratches on surface and head will get damaged.
