2-24-2015 Updated Hard Drive & Hard Drive PCB stock file. Well over 30,000 items stock
Attached is our most current/updated inventory files (2/24/2015) for our hard drives and hard drive PCB's. 24,000+ hard drives stock and 16,000+ hard drive PCB's stock:
http://www.effectiveelectronics.comEffective Electronics, LLC is a stocking distributor of Exact Donor Hard Drives and Exact Hard Drive Printed Circuit Boards for the Data Recovery field. We stock 24,000 hard drives and 16,000 printed circuit boards for hard drives. All of our drives have been professionally tested and DOD (Department of Defense) wiped of all data. All of our printed circuit boards have been professionally tested and functioning 100%. We have been selling hard drives and printed circuit boards since 1999. We are professionals in the field of supplying Data Recovery companies with hard to find donor drives and PCB’s. Our website is designed with the Data recovery field as our number one priority! All of our drives are listed individually with the exact photo of each drive and all the important affiliated details to guarantee you get the exact donor drive you require.
If you need assistance, we can be contacted at
customerservice@effectiveelectronics.com or IM us @ effectelec or you can call us directly @ Ph: 407-463-0699
- Attachments
- HDDGURU-HARD-DRIVE-PCB-FILE.xlsx
- Current list 2/24/2015 hard drive PCB's stock
- (91.25 KiB) Downloaded 1613 times
- HDDGURU-HARD-DRIVE-FILE.xlsx
- Current list 2/24/2015 hard drives stock
- (124.29 KiB) Downloaded 1511 times
