October 18th, 2023, 2:30
October 18th, 2023, 11:15
October 18th, 2023, 14:46
October 18th, 2023, 15:02
October 18th, 2023, 17:19
October 18th, 2023, 17:52
October 18th, 2023, 17:55
pepe wrote:Actually it seems to have separate host sata connector for each adapter connector.
October 20th, 2023, 4:48
fzabkar wrote:pepe wrote:Actually it seems to have separate host sata connector for each adapter connector.
That would be the correct way to do it. Otherwise, if you were to bus all the inputs to a single output connector, you would create reflective stubs.
I quite like the design of this adaptor, especially its inspection windows. If I were in the DR business, I would probably buy one.
October 20th, 2023, 4:57
fzabkar wrote:I think that the HDD on the bottom side is an SFF-8784 model.
https://recuperodatos.com/sites/default/files/webform/donantes/03775-PCB.jpg
https://recuperodatos.com/sites/default/files/webform/donantes/03775-D.jpg
October 20th, 2023, 5:01
February 2nd, 2024, 11:26
February 5th, 2024, 4:14
Skye wrote:Are you still making/selling this adapter? I emailed some time back but have not received a response back.
